    2. Jonas Leite
    Jonas LeiteJ Offline
    • Posts 7
    Jonas Leite
    @Jonas Leite
    Jonas Leite Unfollow Follow
    • RE: Getting data from Google Sheets
      It worked. The error was in credential.json, TRIGGERcmd couldn't find the file, so I entered the data directly into the python file.
      Good job. Thanks for the help my friend.
      Jonas LeiteJ
      Jonas Leite
      @Russ I managed to get the code to work, see below. Is correct? It is taking the values ​​from the spreadsheet.
      import gspread
      from oauth2client.service_account import ServiceAccountCredentials
      # Configurar as credenciais do Google Sheets
      scope = ['https://spreadsheets.google.com/feeds',
               'https://www.googleapis.com/auth/drive']
      creds = ServiceAccountCredentials.from_json_keyfile_name('serviceaccount.json', scope)
      client = gspread.authorize(creds)
      # Abrir a planilha pelo seu ID
      sheet = client.open_by_key('1TuSui3-9aPT0jwJuEJ5S-VmBzue1jnKFbdCAprm_DIk')
      # Acessar a planilha desejada
      worksheet = sheet.get_worksheet(1)  # Supondo que seja a primeira aba da planilha
      # Ler o valor de uma célula específica
      cell_value = worksheet.acell('E11').value
      print("Valor da célula E11:", cell_value)
      import os
      import subprocess
      home_folder = os.path.expanduser('~')
      batch_script_relative_path = '.TRIGGERcmdData\SendResult.bat'
      batch_script_path = os.path.join(home_folder, batch_script_relative_path)
      parameters = [cell_value]
      try:
          result = subprocess.run([batch_script_path] + parameters, capture_output=True, text=True, check=True, shell=True)
          print("Output:", result.stdout)
      except subprocess.CalledProcessError as e:
          print("Error:", e)
          print("Output:", e.output)
      But I didn't understand how to put it in TriggerCMD.
      I used the TRIGGERcmd command to execute the “test” command but Alexa only returns “no result.
      Jonas LeiteJ
      Jonas Leite
      Well, I understand the logic, but something is wrong. And I couldn't figure out what it is. Would you help me?
      My command
      import gspread
      # define the scope of the API access
      scope = ['https://spreadsheets.google.com/feeds', 'https://www.googleapis.com/auth/drive']
      # authenticate with the API using the credentials file
      creds = ServiceAccountCredentials.from_json_keyfile_name('credentials.json', scope)
      # open the Google Sheet by its URL
      sheet_url = 'https://docs.google.com/spreadsheets/d/1AgCtusxv7xgLq9G_Q7Ea5YQsEwjg8Klz/edit#gid=0'
      sheet = client.open_by_url(sheet_url)
      # select the first worksheet
      worksheet = sheet.get_worksheet(0)
      # read the value of cell A1
      cell_value = worksheet.acell('E12').value
      print(cell_value)
      ERROR
      Traceback (most recent call last):
        File "C:\Users\jonas\PycharmProjects\Teste do SHEETS\Sheets.py", line 8, in <module>
        File "C:\Users\jonas\AppData\Local\Programs\Python\Python311\Lib\site-packages\oauth2client\service_account.py", line 221, in from_json_keyfile_name
          return cls._from_parsed_json_keyfile(client_credentials, scopes,
        File "C:\Users\jonas\AppData\Local\Programs\Python\Python311\Lib\site-packages\oauth2client\service_account.py", line 171, in _from_parsed_json_keyfile
          raise ValueError('Unexpected credentials type', creds_type,
      ValueError: ('Unexpected credentials type', None, 'Expected', 'service_account')
      The credential is correct, I took the test and managed to authenticate, but when I enter the command you gave me it doesn't work.
      Jonas LeiteJ
      Jonas Leite
    • Getting data from Google Sheets
      I want to get data from a specific cell in Google Sheets. Example: I ask Alexa a question, Alexa how many pieces there are of item A. Then she tells me what is contained in cell A1. Can someone help me?
      Jonas LeiteJ
      Jonas Leite
