btw when i copy and paste the text it takes away the double slash so these are double slashed!
RE: Unexpected token W in JSON at position 273
After I did what you said it happened again except this time it said
Unexpected token } in JSON at position 132
the whole text command editor is just
"trigger": "Sleep",
"command": "C:\Windows\System32\psshutdown /d /t 1",
"ground": "background",
"voice": "Sleep",
]btw i tried psshutdown with and without .exe at the end so the other text editor looks like
"trigger": "Sleep",
"command": "C:\Windows\System32\psshutdown.exe /d /t 1",
"voice": "Sleep",
I'm trying to get my computer to sleep on command.
This is my command line"trigger": "Sleep",
"voice": "Sleep",When I tell it to run a java error pops up with "Unexpected token W in JSON at position 273" and when I write psshutdown \d \t 1 without the whole directory nothing happens.
Thanks, Jaxon
