    2. Dimitar Panayotov
    • Best 1
    Posts made by Dimitar Panayotov
    • Netflix and Spotify (Both Metro Apps) Controlled with simple voice commands (Alexa and Google) with parameters
      Hi I saw that there weren't many solutions for those thus I'm sharing what I have done:
      1. Netflix - You need the metro app from the windows store
        A) Create the following AutoHotkey Script:
         ;Start Netflix with params
         #SingleInstance Force
         AutoTrim , off
         search := ""
         Loop , %0%	; For each parameter:
             search .= %A_Index% A_Space
         Run , netflix:
         WinActivate, Netflix
         If (search = "" or search = "on " or search = "off ")
             ExitApp
             Return
         Sleep, 3000
         CoordMode , Mouse, Screen
         x := 1778
         y := 89
         Click , %x% %Y%
         Sleep , 1000
         Send , %search%
         Sleep , 500
         x := 200
         y := 300
         Click , %x% %Y%
         Sleep , 500
         x := 960
         y := 280
         Click , %x% %Y%
         Sleep , 5000
         x := 1778
         y := 975
         Click , %x% %Y%
         ExitApp
        😎 Create the following TriggerCMD Command:
        C) Create the following IFTTT automation:
      2. Spotify - You need the metro app from the windows store
        ;Start Spotify with params
        AutoTrim, off
        search := ""
        loop, %0%	; For each parameter:
        Run, spotify:
        WinActivate, Spotify Premium
            ExitApp
            Return
        Sleep, 1000
        CoordMode, Mouse, Screen
        x := 45
        y := 135
        Click, %x% %Y%
        Sleep, 500
        Send, ^a
        Send, {Delete}
        Send, %search%
        Sleep, 500
        x := 785
        y := 385
        Click, %x% %Y%
        ExitApp
      With those you can do the following:
      1. Say "Stream {Whatever search even with multiple words} on {Netlifx/Spotify}" and it will start the corresponding app focus it search for whatever you said and play it (And also fullscreen it for Netflix) (Both tested with multiple voice commands and working fine)
      2. Use the Devices TriggerCMD creates and start the apps with them or say "Stream on {Netlifx/Spotify}" (Voice command not tested yet but the devices triggers work) without parameters and it will just open the corresponding app focus it and stop the script.
      I'm using Google Home but the process should be the same.
      Also the assumption is that your resolution is 1920x1080. If not: You'll need to adjust the values for x and y mouse positions for where to click on the respective apps.
      I hope that this will come in handy. 🙂
      To the author of TriggerCMD: You have created a great software!!! Good job mate, I'm just waiting for my paycheck (Don't ask ... spending money like a maniac on smart accessories and bushcraft items....) and subscribing to TriggerCMD at the end of the month! 🙂
      Have a great day!
      Dimitar PanayotovD
      Dimitar Panayotov
