    2. Chris Kunze
    C Offline
    • RE: GH and X10 no longer working as expected
      This makes a lot of sense (because most of the "on" commands are the ones experiencing issues. I'm at work now, but will modify the commands when I return home and post the results. Thanks again for your assistance.
      UPDATE: The issue is resolved. Removing the "on" from the end of the voice field fixed the problem. Thanks again!
      C
      Chris Kunze
      I typically say "hey Google, turn on kitchen lights". I have a few phrases I can use because I set up routines in Google Assistant to "tell triggercmd to run kitchen lights on" (which is the triggercmd command) when I say several variations of "turn on kitchen lights" or "turn kitchen lights on".
      I've also said "hey google, tell triggercmd to run kitchen lights on on mainpc" to eliminate any possible conflict with the google home routine. Still no luck.
      The odd thing is that saying "hey google, turn kitchen lights off" still works, along with about 1/2 my other commands. The other half (that don't work) give the me the response "say something like run calculator on office pc". I'm trying to figure out why this has stopped working for about 1/2 my commands. Like I said, for about 6mo, no issues at all.
      C
      Chris Kunze
    • GH and X10 no longer working as expected
      Hello. About 6-8mo ago I followed the tutorial to set up a custom command.json file to run various commands through my x10 modules and Google Home. Up until late January everything was working perfectly. However, now certain commands give the voice response "say something like run calculator on office pc".
      The command file hasn't changed and I can successfully initiate the action through the batch file I created and also through the triggercmd web interface. Additionally, some of the commands still work as expected through voice command.
      Any suggestions? I looked to see if anyone else was having the same symptoms, but didn't see anything that was related. I can copy/paste any info needed to diagnose.
      C
      Chris Kunze
