    2. Carter Brewer
    Carter BrewerC Offline
    Carter Brewer
    @Carter Brewer
    Carter Brewer Unfollow Follow
    • where do I type code and what goes in the command section of GUI cmd editor
      I got an Alexa for Christmas and I ended up using TRIGGERcmd for a few things. I've watched most of the videos and I have the full version. I can get some of the commands I created to works, but not all of them. I keep seeing things I want to do but it involves using code. Where do I type this code? I run command prompt as Admin but I cant get the code to work, I even tried copy and pasting said code.
      I'm also not sure how TRIGGERcmd works, so I don't know how much of the line of code to use in the command section of the GUI editor. And some of the Example commands wont work. I get a prompt that says "this app cant run on your PC" (this typically happens when I try to lock my pc with TRIGGERcmd
      Carter BrewerC
      Carter Brewer
