    2. Caio Kenup
    C Offline
    • Issue when passing URL as parameter
      I have the very simple trigger that runs
      curl [params]
      So I can make GET requests to a local address remotely via the triggerCMD API. (If you think this is a work around using localtunnel or ngrok, it is exactly that)
      My triggerCMD API request looks like this
      https://www.triggercmd.com/api/run/triggerSave?computer=<MY_COMPUTER>&trigger=curl&token=<MY-TOKEN>&params="http://localhost:4040/webhook/id?par1=1&par2=b&par3=temp"
      The request only passes the first argument (par1 = 1), making me think the "&" character is improperly interpreted, despite being between quotes.
      The curl command runs correctly through the terminal
      curl "http://localhost:4040/webhook/id?par1=1&par2=b&par3=temp"
      passing all three arguments, again adding weight to the possibility that the API call is doing something to URL when passed as parameter.
      Any insight on how I could get this to work would be greatly appreciated!
      C
      Caio Kenup
