    2. Alcir Junior
    Posts made by Alcir Junior
    • RE: Difficulty executing commands in the shell script
      Hello russ, thank you very much it worked perfectly.
      Thank you.
      Alcir JuniorA
      Alcir Junior
    • Difficulty executing commands in the shell script
      Hello everyone I'm having trouble running some command lines in my shell script:
      #!/bin/sh
      # cd Cloud/laradock && docker-compose stop
      open -a mail
      open -a whatsapp
      open -a slack
      cd ~/Cloud/laradock && docker-compose up -d nginx mysql postgres mongo redis
      open -a google\ chrome http://dev.laravel.library
      code -n ~/Cloud/Dropbox\ \(Personal\)/Projects/Caju/PHP/Frameworks/Laravel/Library/
      open -a memory\ clean\ 2
      All lines that start with the open command execute normally, but the lines that I access a folder to run the docker-compose and the line where I execute the command to open a folder in vscode using the code does not work.
      Has anyone ever experienced this, thanks?
      Alcir JuniorA
      Alcir Junior
