    2. A McF
    A Offline
    • 32 Bit GUI TriggerCMD Editor
      Re: Is there a 32bit Agent for Windows available?
      As I run TriggerCMD on a 32Bit Windows 10 mini pc, I have written a small -simple 32Bit GUI TriggerCMD editor. I have made it available at the following link ...
      https://drive.google.com/drive/folders/1-7Kx2Qh6SMQIU2t0fybJ4aiefbc6e9Za?usp=sharing
      A
      A McF
    • RE: Open YouTube In Chrome, Search and Play Result Fullscreen
      @a-mcf NOTE: The path to Chrome broweser in the code, is that of the 32Bit version and would be different on a 64Bit machine.
      A
      A McF
    • Open YouTube In Chrome, Search and Play Result Fullscreen
      Re: Open YouTube in default broswer and query search term
      The following VBScipt code will accept a search term as a parameter, select and follow a link from the search results, and play the video fullscreen. My web browser is Google Chrome.
      For Each a In WScript.Arguments
      param = param & a & " "
      Next 'a
      param = LCase(Trim(param))
      Set WSS = CreateObject("Wscript.Shell")
      arg = "https://www.google.ca/search?q=" & param & " site:youtube.com"
      strURL = Chr(34) & "C:\Program Files\Google\Chrome\Application\chrome.exe " & Chr(34) & " " & Chr(34) & arg & Chr(34)
      WSS.Run strURL
      WSS.AppActivate "Google Chrome"
      Wscript.sleep 2000
      WSS.sendkeys "{TAB}"
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      Wscript.sleep 300
      WSS.sendkeys"{enter}"
      Wscript.sleep 7500
      WSS.sendkeys "+{f}"
      Set WSS = Nothing
      A
      A McF
    • Search And Play A Movie By Title, Subtitle or Random
      My code formatting in this post apparently suck! Oops.
      I could say:
      ' Hey Google tell trigger command movie with parameter die hard' the movie should be found and played.
        "trigger": "Movie",
        "command": "PlayMovie.vbs",
        "ground": "foreground",
        "voice": "movie",
        "allowParams": "true"
      Create PlayMovie.vbs with these contents:
       ' Author:   Allan McFarlane (2018)
       ' Purpose:  Locates And Play First Movie Whose Title Or
       '           SubTitle Matches The Passed Parameter(s).
       '           If There Is No Parameter A Random Movie Is Played.
       ' Inputs:   Complete Or Partial Movie Title Or SubTitle, Or None.
       ' Returns:  Message Box Will Be Shown If No Match Was Found.
       ' Notes:    I Use MediaPlayerLite As A Player, It's Installer Offers To Install
       '	     Crapware That Can Be Declined When Installing.
       '	     All Movies Are Stored In A Single Folder Called 'Movies'.
       '           Each Movie File Is Stored In It's Own Folder In The Movies Folder.
       '           Searching Is Based Only On The Folder Name.
       '           Movie Year Should Not Be A Parameter.
       '           The Words 'The' And 'A' Can Be Used, But, Will Be Internally Dropped.
       '           Only The 'MP4' Encoded Video File Types Are Played By This Script.
       '           Movie Folders Follow The Following Naming Conventions:
       '           Butterfly Effect 2, The (2006)
       '           Catwoman (2004)
       '           Poison Ivy 4 _ The Secret Society (2008)
       '           Pirates of the Caribbean 1 _ The Curse of the Black Pearl (2003)
       '           RoboCop REMAKE (2014)
       '           Simple Plan, A (1998)
       '           Spider-Man 2 (2004)
       '           Nine And A Half Weeks (1986)
       ' root needs to be set as the path to the 'Movies' folder
      root = "\\GOFLEX_HOME\GoFlex Home Public\Movies\"
      	arg = arg & a & " "
      Next 'a
      arg = LCase(Trim(arg))
      If Left(arg, 4) = "the " Then 'discard superfluous leading THE from parameter
          arg = Right(arg, Len(arg) - 4)
          padding2 = 5
      ElseIf Left(arg, 2) = "a " Then 'discard superfluous leading A from parameter
          arg = Right(arg, Len(arg) - 2)
          padding2 = 3
      End If
      Set fso = CreateObject("Scripting.FileSystemObject")
      Set oFolders = fso.GetFolder(root) 'main folder that contains all sub folders, which contain the actual movie
      success = 0
      If arg <> "" Then
          For Each oFolder In oFolders.SubFolders 'loop through sub folder list
              padding = padding2
              If padding = 0 Then 'account for lenght of possible trailing text THE or A
                  If InStr(LCase(oFolder.Name), ", a") > 0 Then
                      padding = 3
                  End If
                  If InStr(LCase(oFolder.Name), ", the") > 0 Then
                      padding = 5
                  End If
              End If
              If InStr(oFolder.Name, "(") > 0 Then 'prepare for exclusion of trying to match release year ie: (2006)
                  padding = padding + 7
              End If
              subStart = 0
              subTitle = ""
              subStart = InStr(oFolder.Name, "_") 'test for existence of possible subtitle
              If subStart > 0 Then 'fetch simple title and subtitle if present
                  Title = LCase(Left(oFolder.Name, subStart - 1))
                  subTitle = LCase(Mid(oFolder.Name, subStart + 1, Len(oFolder.Name) - subStart - padding))
              Else
                  Title = LCase(oFolder.Name)
              End If
               'does this folder's title or subtile contains a match to the parameter?
              If InStr(Title, arg) > 0 Or InStr(subTitle, arg) > 0 Then
                  Set oFiles = oFolder.Files
                  For Each oFile In oFiles 'loop through filenames to find my MP4 encoded movie
                      If InStr(LCase(oFile.Name), ".mp4") > 0 Then
                          arg = root & oFolder.Name & "\" & oFile.Name 'build path to movie file
                          'build string for specific executable with compatible command line arguments
                          success = 1
                          arg = Chr(34) & "C:\Program Files\MediaPlayerLite\mpl.exe " & Chr(34) & " " & Chr(34) & arg & Chr(34) & " /fullscreen"
                          CreateObject("Wscript.Shell").Run arg 'run it!
                          Exit For
                      End If
                  Next
                  Exit For
              End If
          Next
      Else
          'No movie to search for, so play a random movie
          folderCount = oFolders.SubFolders.Count
          Randomize
          folderNum = Int((folderCount - 1 + 1) * Rnd + 1)
          curFolderNum = 0
              curFolderNum = curFolderNum + 1
              If curFolderNum = folderNum Then
                  For Each oFile In oFiles 'loop through filenames to find the MP4 encoded movie
                          success = 1
                          Exit For
                      End If
                  Next
                  Exit For
              End If
          Next
      End If
      Set fso = Nothing
      If success = 0 Then
          WScript.Echo "No Match Found!" & vbCrLf & arg
      End If
      A
      A McF
