    TriggerCMD skill working, but not directly
    22 Posts 5 Posters 6.6k Views 1 Watching
    • R Offline
      rafaelramon @Russ
      This post is deleted!
      • P Offline
        PedroMartins
        I was facing the same problem, but solved while writing this:
        If I use the old skill and say "ask trigger CMD to run terço" it works perfect, also works from pressing "trigger" in the website.
        If I use the new skill and say "turn on terço" it doesn't.
        What have I tried:
        • Disabling and enabling the skills.
        • Deleting and adding the command again.
        • Removing and discovering the comands again in Alexa.
        • Removing and re-installing the triggercmdagent.
        • Changing voice command.
        Useful info:
        • Only happens to that command, all the other works fine.
        • This command is a bash script that open a few chrome pages depending on week day.
        • I'm using Linux (PopOS 20.04).
        • I'm using it in portuguese.
        Then I decide to try changing the Trigger name. I used "batata" (potato in portuguese) and it worked, then I tried "Terço" again and it didn't, then I tried "Terco", it worked. Apparently it is a problem with "ç" in the trigger name (in the voice command is working well). Since english don't have that, it's understandable. It's not a big thing or really a problem, just wanted to inform so if anyone is having the same problem, try that.
