    Install TriggerCMD agent on your NAS OR Router
    Instructions
    1.7k
    • S
      stevef9432203
      Entware What is it -
      Entware is a package manager that has support for embedded devices including
      Asus, WD Pro, Thecus, Qnap, Synology, Zyzel, Voxel, Linksys,
      DD-Wrt, Tomato, Shibby, Open-WRT.
      It is a modern alternative to Optware and was originally designed for use on OpenWRT
      but has been adapted for use on other distributions, it is similar to apt/yum/pacman in
      that it will allow you to install over 2000+ Linux applications, no longer will you
      have to use docker or hacky addons.
      Minimum Requirements - Extra storage (Small HD preferred,but will work with USB stick)
      Also Router should have 128M or ram. The TriggerCMD will use about 25M of ram.
      Entware - Is an addon for Embedded devices "Routers, Access Points, and Nas"
      that with install of Entware Repo adds an addtional 2200 additional apps to what
      is in your Router or Nas.
      ---->>>> https://entware.net/about.html
      See https://github.com/Entware/Entware/wiki for supported devices
      and Installion notes.
      Perform steps from wiki to install on your Device.
      Once Entware is installed you need to perform these Steps
      using SSh or Telnet
      ######################## INSTALL node-js and utils #################################
      opkg update
      Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz.
      Updated list of available packages in /opt/var/opkg-lists/entware.
      opkg upgrade
      Downloading and updating installed Packages...
      opkg install node-js
      Installing node-js...
      opkg install node-npm
      Install node-npm.....
      opkg install git-http
      Installing git-http tools...
      update npm
      npm update npm
      ths took 4 minutes now have patience...
      ############################# Install TriggerCMD-Agent ############################
      cd /mnt
      Get Mount point
      mount
      ubi:rootfs_ubifs on / type ubifs (ro,relatime)
      devtmpfs on /dev type devtmpfs (rw,relatime,mode=0755)
      proc on /proc type proc (rw,relatime)
      tmpfs on /var type tmpfs (rw,noexec,relatime,size=420k)
      sysfs on /sys type sysfs (rw,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,relatime)
      mtd:bootfs on /bootfs type jffs2 (ro,relatime)
      devpts on /dev/pts type devpts (rw,relatime,mode=600)
      mtd:data on /data type jffs2 (rw,relatime)
      tmpfs on /tmp type tmpfs (rw,relatime)
      /dev/mtdblock8 on /jffs type jffs2 (rw,noatime)
      /dev/sda1 on /tmp/mnt/Backup+Hub type ext4 (rw,nodev,relatime,stripe=8191,data=ordered)
      Your mount point is usually dev/sda1
      on my router /dev/sda1 on {/tmp/mnt/Backup+Hub}
      Now we need to change to the directory returned by you mount command ( not Mine)
      cd /tmp/mnt/Backup+Hub
      Now lets make a "gitrepo" directory
      mkdir gitrepo
      Now change to that directory
      cd gitrepo
      Now lets clone the from Github. -# https://github.com/rvmey/TRIGGERcmd-Agent.git #-
      git clone https://github.com/rvmey/TRIGGERcmd-Agent.git
      Cloning into 'TRIGGERcmd-Agent'...
      remote: Enumerating objects: 65, done.
      remote: Counting objects: 100% (65/65), done.
      remote: Compressing objects: 100% (44/44), done.
      remote: Total 809 (delta 35), reused 44 (delta 21), pack-reused 744
      Receiving objects: 100% (809/809), 17.73 MiB | 11.22 MiB/s, done.
      Resolving deltas: 100% (371/371), done.
      Now install Agent dependencies
      cd to TriggerCMD agent
      cd TRIGGERcmd-Agent
      Now udate dependcy files
      npm install
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN deprecated istanbul@0.4.5: This module is no longer maintained, try this instead:
      npm WARN deprecated npm i nyc
      npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
      npm WARN deprecated jade@1.11.0: Jade has been renamed to pug, please install the latest version of pug instead of jade
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated react-tools@0.13.3: react-tools is deprecated. For more information, visit https://fb.me/react-tools-deprecated
      npm WARN deprecated constantinople@3.0.2: Please update to at least constantinople 3.1.1
      npm WARN deprecated transformers@2.1.0: Deprecated, use jstransformer
      npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
      npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
      npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
      npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      electron@4.0.0 postinstall /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent/node_modules/electron-prebuilt-compile/node_modules/electron
      node install.js
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN triggercmdagent@1.0.1 No repository field.
      npm WARN triggercmdagent@1.0.1 license should be a valid SPDX license expression
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      Just ignore the WARN messages, it will run
      added 1407 packages from 901 contributors, updated 1 package and audited 14059 packages in 164.529s
      ################################## Install the Agent ############################################
      node ./src/agent.js --console
      Daemon install: false
      No token exists. Login to request one.
      prompt: token: c5NiIsImlhdCI6MTU1MDM3NTcyN30.hcOtGZ7U95kS1nhCi4P1-lzDOkjhDobug-Pn4LAFJSY
      Token saved for next time.
      Computer ID 5c68db4062f9b30017477972 saved for next time.
      Write backup completed.
      Initiated command removals
      |> Now connected to https://www.triggercmd.com.
      ___/ For help, see: http://bit.ly/2q0QDpf
      Connected at: Sat Feb 16 2019 19:55:45 GMT-0800 (PST)
      Initiated command adds
      { message: 'Subscribed to 5c68db406477972!' }
      Added Gnome Editor
      If you got these steps you are Alive!!! Control C to Stop
      Startup cmd from my Linux workstation systemd service file
      node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TRIGGERcmdData
      Startup Test of running as root ->>>
      /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# /opt/bin/node ./src/daemon.js --run /root/.TRIGGERcmdData
      Running Linux daemon to run background tasks.
      Logging in with saved token to run background tasks.
      Connected at: Sun Feb 10 2019 12:59:47 GMT-0800 (PST)
      { message: 'Subscribed to 5c608a9f592b050016ee2fff!' }
      Added Reboot
      Added yum update
      Added apt update
      Damn it works -
      ps | grep node
      13393 stever 3076 R grep node
      27544 stever 1098m S node ./src/daemon.js --run /root/.TRIGGERcmdData
      lets Create Entware Startup Script -
      S30TriggerCMDServices -
      #!/bin/sh
      TRGPTH="/tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent"
      prefix="/opt"
      PATH=${prefix}/bin:${prefix}/sbin:/sbin:/bin:/usr/sbin:/usr/bin
      OPID=/opt/var/run/trgcmd.pid
      start() {
      echo "starting trgcmd..."
      cd $TRGPTH
      /opt/bin/node ./src/daemon.js --run /root/.TRIGGERcmdData | logger &
      echo $$ > $OPID
      stop() {
      echo "stopping trgcmd..."
      kill cat $OPID
      status() {
      if [ -f $OPID ]; then
      echo "PID of trgcmd is cat $OPID"
      else
      echo "trgcmd is not running"
      fi
      case "$1" in
      start)
      start
      stop)
      stop
      restart)
      stop
      sleep 3
      start
      status) status
      echo "Usage: $0 (start|stop|restart|status)"
      exit 1
      esac
      exit 0
      Copy this text to a file called S30TriggerCMDServices, and place it in
      /opt/etc/init.d/. chmod the file to 755 (# chmod 755 S30TriggerCMDServices )
      Reboot and you are done.
      If you need contact me via PM
      • F
        FreshN Fruity
        AHOY, Steve F! I'm loving your instruction set, but I had a few questions for you.
        First off, were you on an older version of OpenWRT when you wrote this? Some of the filepaths are different for me on 18.06.4.
        Next, did you intend to embed emoji in your startup script, or is that supposed to be "*)" or something as hovering over it suggests? I assume the latter and would hazard a guess that this forum converts it to an emoticon. I'm just about to finish up with that and see whether TRIGGERcmd starts at boot.
        Finally, I understand the filename suggests that S30* should start with a priority level 30, but my router running 18.06.4 is trying to run it as priority level 1. Nowadays I think OpenWRT uses symlinks to set priority according to a couple of lines within an init script itself, so using classic filenames to set priority without indicating within the file itself the priority with which the script should be executed does not work.
        Once again, thank you!
