    Powershell with KODI: Parameters never work unless they are a single character
    2 Posts 1 Posters 543 Views 1 Watching
    • I Offline
      itsmeblake
      I use a series of PowerShell scripts to control Kodi in windows. This particular one has param enabled and should perform a "global search" on device: Master with Voice Word: Searching (search is used by something else).
      param([string]$search)
      $wshell = New-Object -ComObject wscript.shell;
      $wshell.AppActivate('kodi') ## opens the active kodi window ##
      Sleep 1
      $wshell.SendKeys('{/}') ## sends the hot key to open global search ##
      Sleep 1
      $wshell.SendKeys("$search") ## sends value of the parameter ##
      sleep 1
      $wshell.SendKeys('{enter}') ## presses enter ##
      • When I run this from the triggercmd GUI it works exactly as expected.
      • When I try "... with parameter X." it works and does a search for anything named "X."
      • If i try any word for example "Hercules" it wont work.
      if I try
      "Alexa, ask TRIGGERcmd to run searching on master with parameter Hercules." (should search for anything named Hercules)
      Alexa says
      "I cannot find a computer with the voice word master Hercules.
      I 1 Reply Last reply Reply Quote 0
      • I Offline
        itsmeblake @itsmeblake
        can anyone help with this?
