    Command script not working - Raspberry?
    1.1k
      A Former User
      Hi, not sure what i am doing wrong. I have created a script called test.sh which has the following content:
      #!/bin/bash
      a="hello world"
      echo $a >> test.txt
      it writes a text to another file called test.txt. the script works when I am running it from the command line.
      However, when I run it via triggercmd it's not doing anything. Log shows this:
      Running trigger: Hello World Command: sudo /home/pi/tmp/test.sh
      Reported: Command Ran
      But the command fails to do what it should do.
      This is what i listed in the commands.json file:
      {"trigger":"Hello World","command":"sudo /home/pi/tmp/test.sh","ground":"foreground","voice":"update","allowParams": "false"}
      I also tried without sudo, but no lock.
      Any idea what I am doing wrong?
        A Former User @A Former User
        @Joost-Breggeman said in Command script not working - Raspberry?:
        nevermind... found it. there should be an absolute path to the text file in the script
