    2. Radosław Szałkowski
    Radosław SzałkowskiR Offline
    • RE: Raspberry Pi install failed
      @Russ I have a problem and I don't know what I'm doing wrong - I always have your default configuration file. I even tried to remove and install.
      root@raspberrypi:/home/pi# triggercmdagent
      Daemon install: false
      Logging in with saved token.
      Checking if the 5fb03d4f355bc6001903ba40 computer exists.
      This computer was deleted from your account.  Login to recreate it.
      prompt: token:  mytoken
      Token saved for next time.
      Tokenfile: /root/.TRIGGERcmdData/token.tkn
      ComputerIDfile: /root/.TRIGGERcmdData/computerid.cfg
      Logging in with saved token to run foreground tasks.
      Computer ID 5fb0406efe27220019319bad saved for next time.
      Write backup completed.
        |>    Now connected to https://www.triggercmd.com.
      \___/   For help, see: http://bit.ly/2q0QDpf
              (using sails.io.js node SDK @v1.1.13)
               Connected at: Sat Nov 14 2020 20:39:12 GMT+0000 (Greenwich Mean Time)
      Initiated command removals
      Initiated command adds
      { message: 'Subscribed to 5fb0406efe27220019319bad!' }
      Added Gnome Editor
      ^C
      root@raspberrypi:/home/pi# nano /root/.TRIGGERcmdData/commands.json
      root@raspberrypi:/home/pi# /usr/share/triggercmdagent/app/src/installdaemon.sh
      Daemon install: true
      Checking if the 5fb0406efe27220019319bad computer exists.
      This computer exists in your account.
         Active: active (running) since Sat 2020-11-14 20:42:06 GMT; 1s ago
       Main PID: 11693 (node)
          Tasks: 6 (limit: 2063)
                 └─11693 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      Nov 14 20:42:06 raspberrypi systemd[1]: Started TRIGGERcmd Agent.```
      Maybe you have any idea? Thanks!
      Radosław Szałkowski
