<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Start Spotify Playlists with Smartthings and Trigger CMD]]></title><description><![CDATA[<p dir="auto">Start Spotify Playlists with Smartthings and Trigger CMD   Here is a video of how to do it.<br />
<a href="https://youtu.be/5LNVrFHCKkA" rel="nofollow ugc">https://youtu.be/5LNVrFHCKkA</a></p>
]]></description><link>https://www.triggercmd.com/forum/topic/87/start-spotify-playlists-with-smartthings-and-trigger-cmd</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 23:20:13 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/87.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Oct 2017 11:13:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Wed, 29 Aug 2018 22:30:18 GMT]]></title><description><![CDATA[<p dir="auto">yeah some googling found it already, tnx for the quick response.</p>
<p dir="auto">Im very noobish at this all and most of it is just copy past and reading.</p>
<p dir="auto">What i want is the following, tru smartthings with a virtual button to start a playlist but also to stop the playlist if  the virtual sensor switch  to off.</p>
<p dir="auto">Ive made it so far that i can start a playlist and send the audio tru a spotify connect speaker as so</p>
<p dir="auto">Set WshShell = WScript.CreateObject("WScript.Shell")<br />
Comandline = "C:\Users\Peke\AppData\Roaming\Spotify\Spotify.exe"<br />
WScript.sleep 9000<br />
CreateObject("WScript.Shell").Run("spotify:user:1131846872:playlist:3ztoPH7GPeH9b898dIXcvc")<br />
WScript.sleep 5000<br />
WshShell.SendKeys "^{s}"<br />
WScript.sleep 1000<br />
WshShell.SendKeys "^{RIGHT}"<br />
WshShell.SendKeys "^{d}"<br />
WshShell.SendKeys "{TAB 4}", True<br />
WshShell.SendKeys "+{ENTER}"</p>
<p dir="auto">but what i really also want if the virtual button goes to off that the playlist stops and the sound out of my spotify connect speaker stops playing.</p>
<p dir="auto">Is this possible, if so can you point me in the right direction?</p>
<p dir="auto">Greetz Peke</p>
]]></description><link>https://www.triggercmd.com/forum/post/946</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/946</guid><dc:creator><![CDATA[Pedro Gense]]></dc:creator><pubDate>Wed, 29 Aug 2018 22:30:18 GMT</pubDate></item><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Wed, 29 Aug 2018 21:58:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/pedro-gense" aria-label="Profile: pedro-gense">@<bdi>pedro-gense</bdi></a>, I found on this page you can have SendKeys basically hold shift and type letters with a + like this:</p>
<pre><code>objSendKey.SendKeys("+(joecolantonio)")
<p dir="auto">That would type JOECOLANTONIO in upper case.</p>
]]></description><link>https://www.triggercmd.com/forum/post/945</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/945</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 29 Aug 2018 21:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Wed, 29 Aug 2018 21:49:25 GMT]]></title><description><![CDATA[<p dir="auto">Whats the shortcut for shift?</p>
]]></description><link>https://www.triggercmd.com/forum/post/943</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/943</guid><dc:creator><![CDATA[Pedro Gense]]></dc:creator><pubDate>Wed, 29 Aug 2018 21:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Wed, 10 Jan 2018 09:12:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dlaugh14" aria-label="Profile: dlaugh14">@<bdi>dlaugh14</bdi></a>  That is awesome!    I actually hooked an echo dot to my PC (so I can hear both the PC sound and the Alexa sound at the same time.  I then output my PC (and Alexa)  audio to my home stereo system.  One advantage is I only have to say "Alexa play chill music".  <img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" />  Spotify is set as default player on my Alexa.    I can also just say "Alexa skip" to move to the next song.</p>
]]></description><link>https://www.triggercmd.com/forum/post/442</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/442</guid><dc:creator><![CDATA[Nate Hales]]></dc:creator><pubDate>Wed, 10 Jan 2018 09:12:47 GMT</pubDate></item><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Wed, 10 Jan 2018 09:06:22 GMT]]></title><description><![CDATA[<p dir="auto">UPDATE  I just figured out how to switch between Spotify devices.  it is a .vbs file I made in notepad. Works like a champ.  You can change the amount of times it hits the TAB button (to select different devices) by changing the 3 in  "{TAB 3}".  I have made multiple identical scripts with the only change being this number.  I made Trigger commands that I trigger with Alexa through Smartthings.  "Alexa turn on device 3"</p>
Comandline = ":\Users*<em><strong>YOUR COMPUTER NAME</strong></em>*\AppData\Roaming\Spotify\Spotify.exe"<br />
CreateObject("WScript.Shell").Run("spotify:")<br />
WshShell.SendKeys "{TAB 3}", True<br />
WshShell.SendKeys " "</p>
]]></description><link>https://www.triggercmd.com/forum/post/441</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/441</guid><dc:creator><![CDATA[Nate Hales]]></dc:creator><pubDate>Wed, 10 Jan 2018 09:06:22 GMT</pubDate></item><item><title><![CDATA[Reply to Start Spotify Playlists with Smartthings and Trigger CMD on Fri, 08 Dec 2017 06:49:37 GMT]]></title><description><![CDATA[<p dir="auto">Props to Bubba for the video! -</p>
<p dir="auto">I'm kind of a rookie to cmd scripts - I'm a web developer.</p>
<p dir="auto">I didn't see a command in this video so I thought I'd throw this in here in case there's someone like me.</p>
<p dir="auto">start C:\scripts\spotifyChill.vbs - He didn't mention the command in the video. I set voice command to chill music and now I can just tell Alexa to start trigger command and run chill music on my pc - It works great! No need for Spotify premium to play my music using Alexa. I have my computer right next to Alexa in my living room and PC hooked to TV so "Trigger CMD" will come in very useful.</p>
]]></description><link>https://www.triggercmd.com/forum/post/316</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/316</guid><dc:creator><![CDATA[dlaugh14]]></dc:creator><pubDate>Fri, 08 Dec 2017 06:49:37 GMT</pubDate></item></channel></rss>
