<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry Pi relay wiring photos]]></title><description><![CDATA[<p dir="auto">Here's how to wire up this relay board to open two garage doors.<br />
<a href="https://www.amazon.com/JBtek-Channel-Module-Arduino-Raspberry/dp/B00KTELP3I" rel="nofollow ugc">https://www.amazon.com/JBtek-Channel-Module-Arduino-Raspberry/dp/B00KTELP3I</a></p>
<p dir="auto">Each of the 8 relays has 3 contacts.  Use the two contacts closest to the end with the yellow jumper.  That way the circuit is usually open.<br />
The other end of those wires connect to the garage door openers, where you'd connect a button.<br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200129_164443.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200129_164505.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_114606.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_114637.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_114658.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_114802.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_115049.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://triggercmdagents.s3.amazonaws.com/raspberrypi/20200130_115245.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/topic/608/raspberry-pi-relay-wiring-photos</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 12:26:36 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/608.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jan 2020 18:03:56 GMT</pubDate><ttl>60</ttl></channel></rss>
