<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Windows command ideas: apps, system controls, HTTP devices and AI prompts (no helper scripts)]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I have been building a Windows command set in TRIGGERcmd and wanted to share ideas that are just single-line commands - no .bat, .ps1 or external scripts required. Everything below can be pasted directly into commands.json (adjust names and paths to your setup).</p>
<ol>
<li>Launch apps and Windows tools</li>
</ol>
<p dir="auto">calc - Calculator<br />
notepad - Notepad<br />
code - VS Code<br />
explorer.exe - File Explorer<br />
explorer.exe shell:MyComputerFolder - This PC<br />
explorer.exe shell:Downloads - Downloads folder<br />
taskmgr - Task Manager<br />
cleanmgr - Disk Cleanup<br />
control.exe - Control Panel<br />
ncpa.cpl - Network connections<br />
devmgmt.msc - Device Manager<br />
mmsys.cpl - Sound settings<br />
wt - Windows Terminal<br />
powershell - PowerShell<br />
cmd - CMD<br />
start ms-settings: - Settings app<br />
start ms-settings:network-wifi - Wi-Fi settings<br />
start ms-settings:bluetooth - Bluetooth settings</p>
<ol start="2">
<li>Close apps without helper scripts</li>
</ol>
<p dir="auto">taskkill /IM Code.exe /F<br />
taskkill /IM Obsidian.exe /F<br />
taskkill /IM notepad.exe /F<br />
taskkill /IM CalculatorApp.exe /F<br />
taskkill /IM taskmgr.exe /F<br />
taskkill /IM WindowsTerminal.exe /F<br />
taskkill /IM chrome.exe /F /T</p>
<p dir="auto">Drop /F when you want a graceful close instead of a forced kill. /F does not save unsaved work, so it is worth saying that in the command description.</p>
<ol start="3">
<li>Windows controls in one line</li>
</ol>
<p dir="auto">Lock screen: rundll32.exe user32.dll,LockWorkStation<br />
Sleep / standby: rundll32.exe powrprof.dll,SetSuspendState 0,1,0<br />
Mute toggle: powershell -NoProfile -Command '$w = New-Object -ComObject WScript.Shell; $w.SendKeys([char]173)'<br />
Volume up / down: same line with [char]175 / [char]176<br />
Play / pause: same line with [char]179<br />
Empty Recycle Bin: powershell -NoProfile -Command 'Clear-RecycleBin -Force -ErrorAction SilentlyContinue'<br />
Close only File Explorer windows (taskbar survives): powershell -NoProfile -Command '(New-Object -ComObject Shell.Application).Windows() | Where-Object { $<em>.FullName -like ''*explorer.exe'' } | ForEach-Object { $</em>.Quit() }'</p>
<ol start="4">
<li>HTTP devices and local services</li>
</ol>
<p dir="auto">If you run a small local HTTP bridge (for example for a TV box), you can expose remote keys with curl. A POST to <a href="http://localhost:5555/api/send_key" rel="nofollow ugc">http://localhost:5555/api/send_key</a> with a JSON body such as key = KEY_POWER is enough.</p>
<p dir="auto">Ideas: KEY_HOME (close/exit the current app), KEY_BACK, KEY_MUTE, KEY_VOLUME_UP, KEY_VOLUME_DOWN, plus an /api/open_app endpoint for YouTube/Netflix. The same pattern works for Home Assistant, n8n, a Hermes gateway on 127.0.0.1:8642, or any webhook. Only the trigger name leaves the machine; the command and credentials stay local.</p>
<ol start="5">
<li>Bridge TRIGGERcmd to an AI coding agent</li>
</ol>
<p dir="auto">You can turn a command into a prompt launcher for a local AI agent CLI:</p>
<p dir="auto">opencode run %*</p>
<p dir="auto">Set allowParams to true and use %* so multi-word prompts arrive intact. Redirect the output to a file if you want to read the result later. This is a nice way to ask your coding agent to do something from a phone, a voice assistant or an MCP client.</p>
<p dir="auto">For YouTube searches from voice, another useful command takes the spoken parameter and opens <a href="https://www.youtube.com/results?search_query=" rel="nofollow ugc">https://www.youtube.com/results?search_query=</a> with the text URL-encoded. With Alexa's conversational skill you can say: ask TC to run buscar no youtube with parameter &lt;your search phrase&gt;. Google Assistant currently only sends on/off for Smart Home devices, so it cannot pass arbitrary text.</p>
<ol start="6">
<li>MCP tip</li>
</ol>
<p dir="auto">If you use the TRIGGERcmd MCP server, add mcpToolDescription to each command. The local stdio server then creates one tool per command (run_&lt;computer&gt;_&lt;command&gt;) using that description, so the model knows exactly when to use it. Say clearly whether the command accepts parameters.</p>
<p dir="auto">One gotcha: names are sanitized, so "Volume + TV" and "Volume - TV" both become volume_tv and one tool is lost. Use "Aumentar Volume TV" / "Diminuir Volume TV" instead.</p>
<p dir="auto">Safety notes</p>
<li>/F kills apps without saving; use the graceful version for interactive apps.</li>
<li>Emptying the Recycle Bin is irreversible, so describe it explicitly.</li>
<li>Only trigger names are stored in the cloud - commands, paths and tokens stay on your computer.</li>
<p dir="auto">Hope these ideas help. Happy automating!</p>
]]></description><link>https://www.triggercmd.com/forum/topic/3405/windows-command-ideas-apps-system-controls-http-devices-and-ai-prompts-no-helper-scripts</link><generator>RSS for Node</generator><lastBuildDate>Sun, 29 Nov 2026 03:19:35 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3405.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Nov 2026 01:00:16 GMT</pubDate><ttl>60</ttl></channel></rss>
