<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi]]></title><description><![CDATA[<p dir="auto">I have installed the agent on my Raspberry Pi and entered my token.<br />
Now, I need to know how to create a command to make my Alexa think I have said "Alexa, do the thing"<br />
Can you point me in the right direction?<br />
Thank you in advance!</p>
]]></description><link>https://www.triggercmd.com/forum/topic/2796/i-want-to-be-able-to-trigger-an-alexa-routine-from-a-command-line-with-the-triggercmdagent-installed-on-my-raspberry-pi</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 03:06:25 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2796.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jan 2024 03:08:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Mon, 05 Jan 2026 16:17:42 GMT]]></title><description><![CDATA[<p dir="auto">I use CMDNOWND for this.  <a href="https://dennisbabkin.com/cmdnownd/" rel="nofollow ugc">https://dennisbabkin.com/cmdnownd/</a></p>
<p dir="auto">You pop it in the cmd line like this:  <strong>cmdnownd "D:\Libraries\Documents\batchfile.bat"</strong> and it suppresses the appearance of the cmd window.  Just place the exe in your path.  I keep it in the Windows folder itself.<br />
<img src="/forum/assets/uploads/files/1767628367785-scrsht_cmdnownd.png" alt="scrsht_cmdnownd.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/8834</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8834</guid><dc:creator><![CDATA[Xander]]></dc:creator><pubDate>Mon, 05 Jan 2026 16:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Mon, 05 Jan 2026 13:52:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> Windows 11...</p>
]]></description><link>https://www.triggercmd.com/forum/post/8833</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8833</guid><dc:creator><![CDATA[Matt Lodder]]></dc:creator><pubDate>Mon, 05 Jan 2026 13:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Mon, 05 Jan 2026 13:40:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/matt-lodder" aria-label="Profile: Matt-Lodder">@<bdi>Matt-Lodder</bdi></a>, what OS are you running?  I just tried echo on my Windows laptop and it did <strong>not</strong> pop up a window.</p>
]]></description><link>https://www.triggercmd.com/forum/post/8832</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8832</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Mon, 05 Jan 2026 13:40:02 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Mon, 05 Jan 2026 12:31:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> Do you have a suggested command to run this kind of task entirely silently? "echo" obviously pops a terminal window up briefly...</p>
]]></description><link>https://www.triggercmd.com/forum/post/8831</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8831</guid><dc:creator><![CDATA[Matt Lodder]]></dc:creator><pubDate>Mon, 05 Jan 2026 12:31:21 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Thu, 18 Jan 2024 13:02:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/sparker" aria-label="Profile: sparker">@<bdi>sparker</bdi></a>, <a href="https://www.amazon.com/dp/B07P1MMFRP" rel="nofollow ugc">TRIGGERcmd Smart Home</a> is an Alexa skill, not something you install on your phone, so now I'm not sure if you're talking about the TRIGGERcmd <a href="https://apps.apple.com/us/app/triggercmd/id1505878463?ls=1" rel="nofollow ugc">iOS</a> or <a href="https://play.google.com/store/apps/details?id=com.vandermeyconsulting.triggercmdgplay" rel="nofollow ugc">Android</a> phone app.</p>
<p dir="auto">I wonder if you logged into your account using the "Login with Google" button?  If so, you'd need to set a password in your <a href="https://www.triggercmd.com/user/user/profile" rel="nofollow ugc">profile page</a> before logging into the phone app with a email/password.  The phone apps allow you to use a pair code to login, so you could also try that instead.</p>
<p dir="auto">If you're talking about the Alexa skill, you could try enabling it on you computer instead.  If you use the same browser where you're logged into triggercmd, it won't even prompt for login when you enable the skill.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7655</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7655</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 18 Jan 2024 13:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Thu, 18 Jan 2024 04:10:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> Thank you for your reply.<br />
When I try to install the Triggercmd Smart Home app on my phone, it asks for my username and password to your site, and after I enter it and hit "Sign in" the email and password fields are cleared and nothing happens. What should I do at this point? I tried rebooting my phone as well.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7654</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7654</guid><dc:creator><![CDATA[sparker]]></dc:creator><pubDate>Thu, 18 Jan 2024 04:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to I want to be able to trigger an Alexa routine from a command line with the triggercmdagent installed on my Raspberry Pi on Wed, 17 Jan 2024 13:27:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/sparker" aria-label="Profile: sparker">@<bdi>sparker</bdi></a>, you should start by triggering your commands with the green Trigger button on the website.  After that's working, you can use a bunch of <a href="https://www.triggercmd.com/forum/topic/30/list-of-ways-to-trigger-your-commands">other methods</a> to trigger your commands, but I think you'll want to enable the <a href="https://www.amazon.com/dp/B07P1MMFRP" rel="nofollow ugc">TRIGGERcmd Smart Home Alexa skill</a>.</p>
<p dir="auto">After that's enabled, say "Alexa, turn on calculator" as if calculator is a light bulb you're want to turn on.</p>
<p dir="auto">You don't need an Alexa Routine to run your commands, but now that you've enabled the TRIGGERcmd Smart Home Alexa skill you can run an Alexa Routine whenever one of your commands is triggered.  <a href="https://www.youtube.com/watch?v=nrqj-OwDpGE" rel="nofollow ugc">This youtube video</a> shows you how to configure the routine.</p>
<p dir="auto">You wrote in your title you also want to trigger an Alexa routine from the command line.  For that you should download the <a href="https://docs.triggercmd.com/#/./tcmdCLI" rel="nofollow ugc">tcmd tool</a> for the OS where you want to trigger the commands from.  It doesn't have to be your Raspberry Pi even though your commands are running there.  You could even turn your Raspberry Pi off, but then you'd get emails saying your command didn't run.  You can turn those emails off in your TRIGGERcmd profile.</p>
<p dir="auto">The command you connect to your Alexa routine can be anything.  I often make it "echo" so it doesn't do anything because I'm only interested in the Alexa routine running, not the command itself.</p>
<p dir="auto">Let me know how it goes.</p>
<p dir="auto">I use the ability to run an Alexa Routine all the time.  I have a bunch of little $2 IR remotes that I use to turn my lights on/off in my TV room in the basement.  I did <a href="https://www.youtube.com/watch?v=CkltbMZJXL0" rel="nofollow ugc">a video</a> on that too.</p>
]]></description><link>https://www.triggercmd.com/forum/post/7648</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/7648</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 17 Jan 2024 13:27:43 GMT</pubDate></item></channel></rss>
