<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry Pi image with TRIGGERcmd pre-loaded]]></title><description><![CDATA[<p dir="auto">This <strong><a href="https://agents.triggercmd.com/raspberrypi/tcmd_53.img" rel="nofollow ugc">Raspberry Pi image</a></strong> (updated 2/11/25) has the following features, but you don't have to use all of them:</p>
<li>Home Assistent direct support.  No need for Internet - the agent talks to HA over the LAN if you configure it to.</li>
<li>When the Pi boots, it will audibly tell you the pair code if you plug in headphones to the Pi's headphone jack.
<li>Just plug it into your ethernet, boot the Pi, and listen for the code,</li>
<li>Log into your account, click your name, click Pair, then type the pair code.  <img src="/forum/assets/uploads/files/1727121854834-9dacce44-e866-4c3e-b3eb-2d8b045e5473-image.png" alt="9dacce44-e866-4c3e-b3eb-2d8b045e5473-image.png" class=" img-fluid img-markdown" /></li>
<li>This avoids having to connect a  monitor or ssh in, to read /root/paircode.</li>
</li>
<li>Creates a panel in your account called "IR Remote" that you can control using an infrared remote control.
<li>Unlike the Orange Pi Zero 2 in <a href="https://www.triggercmd.com/forum/topic/2394/orange-pi-zero-2-image-with-triggercmd-agent-pre-installed-and-programmed-for-ir-remote-control?_=1671810198907">this article</a>, you'll need to plug in the IR receiver that comes with the IR remote.</li>
<li>You can also use the <a href="https://play.google.com/store/apps/details?id=com.stuffaboutcode.bluedot&amp;hl=en_US" rel="nofollow ugc">Blue Dot</a> app via Bluetooth.  The image includes a command called Pair Bluetooth that will give you 1 minute to pair your cell phone.</li>
<li>You associate each panel button with a command, then you can run those commands using the physical infrared remote control buttons.</li>
</li>
<li>Creates a "Configure Wireless" command to configure a series of wifi networks in priority order. You run the command with the Parameters button and specify your wifi network SSID's and passwords like this:  network1,password1,network2,password2,network3,password3</li>
<li>Creates two "Garage Door" commands to control two relays you can connect to the Raspberry Pi.</li>
<li>Creates commands to control a <a href="https://www.amazon.com/gp/product/B07BKQ6KCK" rel="nofollow ugc">colored LED strip</a> like in this <a href="https://www.triggercmd.com/forum/topic/1739/control-rgb-led-bike-lights-with-raspberry-pi?_=1671810198912">bike project</a>.</li>
<li>You can plug in a physical button to toggle the LED strip on or off.</li>
<li>During boot the LED's will turn:
<li>Red to indicate the Raspberry Pi is booted.</li>
<li>Blue to indicate it has Internet access.</li>
<li>Green to indicate it is talking to the TRIGGERcmd API (after you pair it with your account).</li>
</li>
<p dir="auto">It should show up on your LAN as triggercmd-rpi.</p>
<p dir="auto">The default password for the <strong>"pi"</strong> user is <strong>"triggercmd"</strong> but you should change it.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1671834091305-rpi_irled-relay-btn.png" alt="rpi_irled-relay-btn.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1671811603144-img_20221222_200708223.jpg" alt="IMG_20221222_200708223.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">You can use the official Raspberry Pi Imager to write this image to your MicroSD card.  Just select "Use custom" and select <a href="https://drive.google.com/file/d/1myDtenqWep6hHtP9oCTTiqv26_dEw5aH/view?usp=drive_link" rel="nofollow ugc">the image file</a>:<br />
<img src="/forum/assets/uploads/files/1727121315915-374810ae-e956-4a6d-ba2f-020cde3a0190-image.png" alt="374810ae-e956-4a6d-ba2f-020cde3a0190-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">LED strip:<br />
<a href="https://www.amazon.com/gp/product/B0888HYCJN" rel="nofollow ugc">https://www.amazon.com/gp/product/B0888HYCJN</a></p>
<p dir="auto">Dual relay board:<br />
<a href="https://www.amazon.com/SunFounder-Channel-Optocoupler-Expansion-Raspberry/dp/B00E0NTPP4" rel="nofollow ugc">https://www.amazon.com/SunFounder-Channel-Optocoupler-Expansion-Raspberry/dp/B00E0NTPP4</a></p>
<p dir="auto">IR Receiver:<br />
<a href="https://www.amazon.com/VS1838B-Universal-Infrared-Receiver-Starter/dp/B087ZRD3LH" rel="nofollow ugc">https://www.amazon.com/VS1838B-Universal-Infrared-Receiver-Starter/dp/B087ZRD3LH</a></p>
<p dir="auto">IR Remote Control with IR Receiver and wires:<br />
<a href="https://www.amazon.com/Infrared-Control-Receiver-Raspberry-arduino/dp/B0981DBCY9" rel="nofollow ugc">https://www.amazon.com/Infrared-Control-Receiver-Raspberry-arduino/dp/B0981DBCY9</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1667086010350-fa18683c-39c9-4efd-a613-4c382c8b9968-image.png" alt="fa18683c-39c9-4efd-a613-4c382c8b9968-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/topic/2474/raspberry-pi-image-with-triggercmd-pre-loaded</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 01:04:30 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/2474.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Dec 2022 15:52:52 GMT</pubDate><ttl>60</ttl></channel></rss>
