<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alexa Google Panic Alarm]]></title><description><![CDATA[<p dir="auto">I got thinking about this last night.<br />
My security system can be set to automaticaly arm/disarm at a specific time and I can do this via voice. The wireless keyflob have a Panic function as does the security remote. Neither of these I take to bed or even carry with me.<br />
What better use of Alexa/Google then to trigger a Panic Alarm?</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1970/alexa-google-panic-alarm</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 04:26:31 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1970.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Jan 2022 18:28:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alexa Google Panic Alarm on Sun, 23 Jan 2022 15:15:16 GMT]]></title><description><![CDATA[<p dir="auto">Yesterday I did a clean up of my HomeGenie disabling things I thought I no longer needed. After this I tested my Panic Alarm and discovered there were a few things required that I had left out. These may have been set by default with the initial install of HomeGenie.</p>
<li>Besides the Demo-Toggle Door having to be enabled the Virtual Modules Demo program must also be enabled.</li>
<li>As well the Automation.Demo 2 "DoorSensor" need to have the options to "Use as security sensor" and "Also trigger when armed Home" checked.</li>
<li>The Automation.Demo 2 "DoorSensor" has to be in the closed condition prior to arming the security widget or you will need to send 2 panic calls</li>
]]></description><link>https://www.triggercmd.com/forum/post/5351</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5351</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 23 Jan 2022 15:15:16 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa Google Panic Alarm on Sun, 16 Jan 2022 13:05:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> said in <a href="/forum/post/5248">Alexa Google Panic Alarm</a>:</p>
<blockquote>
<p dir="auto">The wireless keyflob have a Panic function as does the security remote. Neither of these I take to bed or even carry with me.</p>
</blockquote>
<p dir="auto">Wait a min. I have a fitbit that has Alexa ability!<img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60e.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--sunglasses" style="height:23px;width:auto;vertical-align:middle" title="😎" alt="😎" /><br />
So in theory I always have a remote on me.<img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f616.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--confounded" style="height:23px;width:auto;vertical-align:middle" title="😖" alt="😖" /><img src="https://www.triggercmd.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f923.png?v=6297cc46437" class="not-responsive emoji emoji-android emoji--rolling_on_the_floor_laughing" style="height:23px;width:auto;vertical-align:middle" title="🤣" alt="🤣" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/5260</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5260</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 16 Jan 2022 13:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa Google Panic Alarm on Sat, 22 Jan 2022 23:32:20 GMT]]></title><description><![CDATA[<p dir="auto">Ok I got this working using the demo Door/Window widget address included in a HomeGenie initial setup.<br />
here is the line you'd need for the TRIGGERcmd command.json file.</p>
<pre><code>{"trigger":"Panic","command":"curl http://IP&amp;Port/api/HomeAutomation.HomeGenie/Automation/Programs.Run/401","ground":"background","voice":"Panic","allowParams":"false"},
<p dir="auto">Change the IP&amp;Port to the IP &amp; Port of your HG server seems the Security system has to have been in an Armed state for a bit for it to work maybe due the the Arm Away I was using to test things.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5258</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5258</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sat, 22 Jan 2022 23:32:20 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa Google Panic Alarm on Sat, 15 Jan 2022 14:15:50 GMT]]></title><description><![CDATA[<p dir="auto">Since creating a trigger script for <a href="https://www.triggercmd.com/forum/topic/1969/arm-disarm-security-system-via-google-alexa">Arming &amp; Disarming</a> via voice.  I believe I'm come up with a way to do this via calling the demo door/window sensor that originally comes with HomeGenie using the API.<br />
I may rename it to panic and see if I can get TRIGGERcmd to run it.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5255</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5255</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sat, 15 Jan 2022 14:15:50 GMT</pubDate></item></channel></rss>
