<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HomeGenie X10 control with single bash script]]></title><description><![CDATA[<p dir="auto">Actually I believe this (<a href="http://HG.sh" rel="nofollow ugc">HG.sh</a>)will work for all HomeGenie configured switches, lights or plugs no mater the protocol.<br />
I've tested with Zwave and X10 so far .</p>
<pre><code>#!/bin/bash
echo "Sending HomeGenie the $1 command $2 to turn $3"
curl http://192.168.0.24:8084/api/HomeAutomation.$1/$2/Control.$3
<p dir="auto">Naturally you'd change the IP &amp; port # to that of your HG server.<br />
To test:</p>
<li>1: Make the <a href="http://HG.sh" rel="nofollow ugc">HG.sh</a> file executable (chmod +x <a href="http://HG.sh" rel="nofollow ugc">HG.sh</a>)</li>
<li>2: From command line for X10 type: sh <a href="http://HG.sh" rel="nofollow ugc">HG.sh</a> X10 A3 On<br />
This turns on X10 module A3</li>
<li>3: From command line for ZWave type: sh <a href="http://HG.sh" rel="nofollow ugc">HG.sh</a> ZWave 1 On<br />
This turns on ZWave node 1</li>
<li></li>
<p dir="auto"><strong>Update:</strong> I added a Dim preset to the script so a new script isn't required for that.</p>
foo=$(echo "${3}" | awk '{$1=toupper(substr($1,0,1))substr($1,2)}1')
if [ $foo = "Dim" ]
then(
#following turns device to 20% brigtness if you wish it to be different change the value between 1-100 where 100 is full brightness
curl http://192.168.0.24:8084/api/HomeAutomation.$1/$2/Control.Level/20
echo "Sending HomeGenie the $1 command $2 to Dim"
else(
curl http://192.168.0.24:8084/api/HomeAutomation.$1/$2/Control.$foo
echo "Sending HomeGenie the $1 command $2 to turn $foo"
fi
echo Sent HomeGenie the $1 command $foo to $2 &gt;&gt; /home/pi/scripts/HGsents.txt
<p dir="auto">To use this with Alexa and or Google you need to edit the commands.json file<br />
<em><strong>For X10 on/off add lines like:</strong></em></p>
<pre><code>#{"trigger":"a8","command":"/home/pi/scripts/HG.sh x10 A8","ground":"background","voice":"?","allowParams":"true"},
<p dir="auto">change a8 and A8 to match the x10 address you require and change the ? to a friendly name for Alexa &amp;or Google<br />
<em><strong>For X10 dim add lines like:</strong></em></p>
<pre><code>#{"trigger":"a8","command":"/home/pi/scripts/HG.sh x10 A8 Dim","ground":"background","voice":"?","allowParams":"false"},
<em><strong>For ZWave on/off add lines like:</strong></em></p>
<pre><code>#{"trigger":"ZWave","command":"/home/pi/scripts/HG.sh Zwave
8 ","ground":"background","voice":"?","allowParams":"true"},
<p dir="auto">change the 8 to the node# you wish to control<br />
<em><strong>For ZWave Dim add lines like:</strong></em></p>
<p dir="auto">change the 8 to the node# you wish to control</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1941/homegenie-x10-control-with-single-bash-script</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 00:24:14 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1941.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Jan 2022 18:59:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sun, 06 Feb 2022 21:16:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> thanks, I removed the deviceType from my json file and  had Alexa rediscover and they do still dim.  I edited my previous post.<br />
It should be noted that using dim turns the device to that value. So if you turn a light on (100%) then say dim 20% it doesn't set the light level to 80 but instead sets the light level to 20.<br />
At least that's the way it works for HG.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5504</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5504</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 06 Feb 2022 21:16:05 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sun, 06 Feb 2022 17:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> said in <a href="/forum/post/5500">HomeGenie X10 control with single bash script</a>:</p>
<blockquote>
<p dir="auto">"deviceType":"light"</p>
</blockquote>
<p dir="auto">This is actually wrong ^.  "deviceType":"light" is not a thing.</p>
<p dir="auto">If adding that made it work, it's because when you change a command, TRIGGERcmd deletes and re-creates the Alexa smart home device.  That needed to happen for the Alexa device associated with your command would have the new brightness feature.</p>
<p dir="auto">Sorry I didn't tell you that in <a href="https://www.triggercmd.com/forum/topic/1955/feature-request-add-ability-to-dim-with-alexa-google/12">my reply</a> to your post where I told you it should work now.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5501</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5501</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 06 Feb 2022 17:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sun, 06 Feb 2022 20:50:41 GMT]]></title><description><![CDATA[<p dir="auto">I'm happy to report the above posted script works for Dimming via Alexa since <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> added support in the Alexa skill.<br />
You do need to have Alexa rediscover those dimmable lights</p>
]]></description><link>https://www.triggercmd.com/forum/post/5500</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5500</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 06 Feb 2022 20:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Wed, 26 Jan 2022 17:04:31 GMT]]></title><description><![CDATA[<p dir="auto">I reworked the hg script to handle how I suspect alexa or Google will send the dim command to TRIGGERcmd  when(if) <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> is able to add that feature it presumes the HG server is running on the same PI as TRIGGER and is on port 8080</p>
if [ -n "$foo" ] &amp;&amp; [ "$foo" -eq "$foo" ] 2&gt;/dev/null;
then(
#following turns device to the brigtness level
curl -s http://localhost:8080/api/HomeAutomation.$1/$2/Control.Level/$foo
echo "Sent HomeGenie the $1 command $2 to $foo % brightness"
else(
 curl -s http://localhost:8080/api/HomeAutomation.$1/$2/Control.$foo
echo "Sent HomeGenie the $1 command $2 to turn $foo"
fi
#if next line uncomented it will log commands sent to a already created file HGsents.txt
#echo Sent HomeGenie the $1 command $3 to $2 &gt;&gt; /home/pi/scripts/HGsents.txt
<p dir="auto">You can test the script from the command line for on/off and dim<br />
Using <em><strong>sh <a href="http://hg.sh" rel="nofollow ugc">hg.sh</a> X10 A3 50</strong></em>  this would set the X10 module A3 to 50%<br />
for those that don't wish to create this file you can download it here: <a href="/forum/assets/uploads/files/1643216630554-hg.sh">script</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/5405</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5405</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 26 Jan 2022 17:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Wed, 12 Jan 2022 19:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/wholepunch" aria-label="Profile: wholepunch">@<bdi>wholepunch</bdi></a>, since  <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>  posted <a href="https://www.triggercmd.com/forum/post/5208">https://www.triggercmd.com/forum/post/5208</a>  I got thinking about  HG responding back to the API request. It may be possible to add a custom response to device calls indicating that HG did actually receive and perform the task.<br />
Creating a variable Received for the Curl call<br />
then using  a</p>
<pre><code>"if [ $Recieved='{"ResponceValue":OK}' ]
then
<p dir="auto">one could have TRIGGERcmd report that HG did indeed send the command or not via Alexa or Google.</p>
<p dir="auto">I don't wish to play with Voice Monkey unless I have to.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5224</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5224</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 12 Jan 2022 19:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Wed, 12 Jan 2022 16:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> That's useful to know - thank you! I must admit that I thought that pure X10 devices had been steam-rollered by ZWave, ZigBee at al - but that just shows you what a home automation noob I am. I fully agree with your comments re: some other HA systems - Hassio in particular seems to want to move to a binary " that's supported/not supported" model, which I understand for the purposes of user friendliness and stability, but it's frustrating for the tinkerer!</p>
]]></description><link>https://www.triggercmd.com/forum/post/5223</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5223</guid><dc:creator><![CDATA[Wholepunch]]></dc:creator><pubDate>Wed, 12 Jan 2022 16:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Wed, 12 Jan 2022 15:44:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/wholepunch" aria-label="Profile: wholepunch">@<bdi>wholepunch</bdi></a>, one thing I like about HomeGenie is it has it's own drivers for X10 unlike the other Multi OS HA software solutions.<br />
The Developer isn't as quick at resolving issues and the user base isn't as big as it use to be(perhaps due to that fact).<br />
The user base that have stuck with it are very knowledgeable so most issues that are discovered are usually fixed with a workaround. Having different built in coding languages means most anyone can develop plugins for it.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5222</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5222</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Wed, 12 Jan 2022 15:44:52 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Wed, 12 Jan 2022 14:12:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> Thanks for this - looks like an elegant solution. I've been putting together a Home Assistant (Hassio) build having tried OpenHab and several others but hadn't come across Home Genie for some reason so you've prompted me to do some research - I find Hassio a bit restrictive / cumbersome for some of the things I want to implement, although the work put into making it a polished user experience is very evident.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5221</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5221</guid><dc:creator><![CDATA[Wholepunch]]></dc:creator><pubDate>Wed, 12 Jan 2022 14:12:40 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sun, 09 Jan 2022 18:07:22 GMT]]></title><description><![CDATA[<p dir="auto">I rarely if ever use dim commands and when I do it is for a single lamp and to set it to a specific level.<br />
Since TRIGGERcmd currently doesn't accept dim commands from Alexa or Google the dim operation is a set value (that works for me) if you wish a different value the script would require editing.<br />
If in the future <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> adds dimming I'll rework this bash script.<br />
I'll edit my OP showing the revised script.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5178</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5178</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 09 Jan 2022 18:07:22 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sun, 09 Jan 2022 00:07:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> , seems Alexa and Google send lower case on/off commands and HomeGenie requires the commands to start with upper case. I'm not sure why with using just 1 parameter this seems to work but with 3 parameters it doesn't</p>
<p dir="auto">In any case I've got a work around for this in the Bash script which I edited to look like this now</p>
echo Sent HomeGenie the $1 command $2 to turn $foo &gt;&gt; /home/pi/scripts/HGsents.txt
<p dir="auto">next I'll start to play with adding dim commands but not sure if TRIGGERcmd will process them from Alexa/Google</p>
]]></description><link>https://www.triggercmd.com/forum/post/5176</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5176</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sun, 09 Jan 2022 00:07:30 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sat, 08 Jan 2022 23:52:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/alwaysbroke" aria-label="Profile: alwaysbroke">@<bdi>alwaysbroke</bdi></a>, there are a number of users still on the X10 band wagon as can be seen on the X10 forums  ( <a href="https://forums.x10.com" rel="nofollow ugc">https://forums.x10.com</a> ).<br />
I have used the  Broadlink RM, Samsung SmartThings developer console, and Ha-Bridge and a few other methods to get Alexa control in the past.<br />
The easiest by far to setup was HA-Bridge however currently there is a issue with adding new devices which started to affect me as well as several others. This lead me to TRIGGERcmd.<br />
I'm not a big fan of subscription fees either but if reasonable and it does what I require it is worth it.<br />
HomeGenie is free and I created several addon plugins for it so interfacing to it is best for me. HA-Bridge did this seamless when it was working. I'm sure Triggercmd will do this as well once I have all the bugs worked out. The limitation of one call per min for the non subscription is slowing testing things up here for sure.  One call every 30 seconds would sure speed up my testing but once everything is setup 1 call per min I think I can live with for most things Alexa and every thing Google Home is used for here.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5175</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5175</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Sat, 08 Jan 2022 23:52:02 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Sat, 08 Jan 2022 23:02:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a> I was wondering if people were still using X10 besides me. I ended up using an old broadlink RM Pro to control mine. I just use the newest Broadlink app, (Not IHC, and no IFTTT) and it controls all my x10 devices and also has ir, so it can also control my dumb TV, surround, fireplace, etc. There is no subscription fees with this either.</p>
]]></description><link>https://www.triggercmd.com/forum/post/5174</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5174</guid><dc:creator><![CDATA[alwaysbroke]]></dc:creator><pubDate>Sat, 08 Jan 2022 23:02:16 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Fri, 07 Jan 2022 22:04:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a>  the cool thing is, like TRIGGERcmd it can be used on a variety of OSs, Mac, Windows, Linux, Raspi</p>
]]></description><link>https://www.triggercmd.com/forum/post/5153</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5153</guid><dc:creator><![CDATA[tuicemen]]></dc:creator><pubDate>Fri, 07 Jan 2022 22:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to HomeGenie X10 control with single bash script on Fri, 07 Jan 2022 21:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/tuicemen" aria-label="Profile: tuicemen">@<bdi>tuicemen</bdi></a>, that's pretty cool.  I might try this.  I didn't realize HomeGenie is opensource.</p>
<p dir="auto"><a href="https://homegenie.it" rel="nofollow ugc">https://homegenie.it</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/5152</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5152</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 07 Jan 2022 21:54:07 GMT</pubDate></item></channel></rss>
