<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Log out user and Sleep on Mac?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have a Mac and would like to know if there is a way to Log Out the active user first and then have it go to sleep. I have noticed that when I manually Log Out and give the Sleep command to Alexa, the TRIGGERcmd.app seems to have stopped running, so the Sleep command no longer works at the Log In screen.</p>
<p dir="auto">The reason for this is that I would like to always have a "clean session" when I wake the Mac and type my user password.</p>
<p dir="auto">Is there a way to run the TRIGGERcmd.app as a background app (launch daemon) before user login?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://www.triggercmd.com/forum/topic/1232/log-out-user-and-sleep-on-mac</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 02:36:33 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/1232.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Mar 2021 15:50:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Fri, 07 Jan 2022 00:56:25 GMT]]></title><description><![CDATA[<p dir="auto">Got a lot of issues with node + brew, this one worked like a charm for me:</p>
<pre><code>osascript -e 'tell application "Finder" to sleep'
]]></description><link>https://www.triggercmd.com/forum/post/5137</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/5137</guid><dc:creator><![CDATA[Renan Correa]]></dc:creator><pubDate>Fri, 07 Jan 2022 00:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Sun, 21 Mar 2021 22:21:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nick-lagang" aria-label="Profile: Nick-Lagang">@<bdi>Nick-Lagang</bdi></a>, you'd make a TRIGGERcmd trigger that runs this command on your Windows PC:</p>
<pre><code>WakeMeOnLan.exe /wakeup 40-65-81-A7-16-23
<p dir="auto">The replace 40-65-81-A7-16-23 with your Mac's mac address.</p>
]]></description><link>https://www.triggercmd.com/forum/post/3802</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3802</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Sun, 21 Mar 2021 22:21:20 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Fri, 19 Mar 2021 22:10:40 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> I installed WakeMeOnLan tool as you recommended, and got it to wake up my Mac locally, but I'm not sure how to make it work through Triggercmd on Alexa. Where should I run the command you said?</p>
]]></description><link>https://www.triggercmd.com/forum/post/3795</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3795</guid><dc:creator><![CDATA[Nick Lagang]]></dc:creator><pubDate>Fri, 19 Mar 2021 22:10:40 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Thu, 18 Mar 2021 21:50:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nick-lagang" aria-label="Profile: Nick-Lagang">@<bdi>Nick-Lagang</bdi></a>, I recommend using Nirsoft's <a href="https://www.nirsoft.net/utils/wake_on_lan.html" rel="nofollow ugc">WakeMeOnLan tool</a> to send the magic packet from your Windows box:</p>
<p dir="auto">You can use a command like this:</p>
<p dir="auto">40-65-81-A7-16-23 would be your Mac's network interface card's mac address.</p>
]]></description><link>https://www.triggercmd.com/forum/post/3791</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3791</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Thu, 18 Mar 2021 21:50:00 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Thu, 18 Mar 2021 20:02:18 GMT]]></title><description><![CDATA[<p dir="auto">I actually have a low power mini-itx pc with windows 10 that I could leave always on if needed to make this work. I've been doing some research on how to get it to wake my Mac but there's not many specific results, or maybe I'm not searching the right way lol... If not asking too much, do you have a way that you could point me, that could work? A Windows 10 pc waking a Mac on wake-on-lan... or maybe even a way over the internet...</p>
]]></description><link>https://www.triggercmd.com/forum/post/3790</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3790</guid><dc:creator><![CDATA[Nick Lagang]]></dc:creator><pubDate>Thu, 18 Mar 2021 20:02:18 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Wed, 17 Mar 2021 21:13:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nick-lagang" aria-label="Profile: Nick-Lagang">@<bdi>Nick-Lagang</bdi></a>, you're welcome.  I'm glad it works for you.</p>
<p dir="auto">To wake your Mac up with wake-on-lan, you need another computer on your network to send a "magic packet" to your Mac.  Do you have something that's always on?  I use a Raspberry Pi to send the magic packet.</p>
<p dir="auto">You might want to try this first to understand how it works:<br />
<a href="https://computers.tutsplus.com/tutorials/how-to-remotely-wake-a-mac-with-an-ios-device--cms-21614" rel="nofollow ugc">https://computers.tutsplus.com/tutorials/how-to-remotely-wake-a-mac-with-an-ios-device--cms-21614</a></p>
]]></description><link>https://www.triggercmd.com/forum/post/3779</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3779</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:13:08 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Wed, 17 Mar 2021 21:03:33 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a> you're a genius... I followed the steps and it works perfectly! I'm sure many other Mac users will find this very helpful! Thanks again for taking the time to look into this and give such an easy and fast solution...</p>
<p dir="auto">Now I'm having trouble setting up the Mac to wake on lan from sleep... I'm not sure if Triggercmd has this option... Do you know any way to set this up that actually works?</p>
<p dir="auto">Anyway, thank you!</p>
]]></description><link>https://www.triggercmd.com/forum/post/3778</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3778</guid><dc:creator><![CDATA[Nick Lagang]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:03:33 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Tue, 16 Mar 2021 23:46:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nick-lagang" aria-label="Profile: Nick-Lagang">@<bdi>Nick-Lagang</bdi></a>, here's how I did it on my mac:</p>
<p dir="auto">Using the root user, I created a <strong>/Library/LaunchDaemons/com.triggercmd.agent.plist</strong> file with these contents:</p>
<pre><code>&lt;?xml version="1.0" encoding="UTF-8"?&gt;
&lt;!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"&gt;
&lt;plist version="1.0"&gt;
&lt;dict&gt;
&lt;key&gt;Label&lt;/key&gt;
&lt;string&gt;com.triggercmd.agent&lt;/string&gt;
&lt;key&gt;WorkingDirectory&lt;/key&gt;
&lt;string&gt;/Applications/TRIGGERcmdAgent.app/Contents/Resources/app&lt;/string&gt;
&lt;key&gt;ProgramArguments&lt;/key&gt;
&lt;array&gt;
&lt;string&gt;/usr/local/bin/node&lt;/string&gt;
&lt;string&gt;src/daemon.js&lt;/string&gt;
&lt;string&gt;--run&lt;/string&gt;
&lt;string&gt;/Users/russ/.TRIGGERcmdData&lt;/string&gt;
&lt;/array&gt;
&lt;key&gt;RunAtLoad&lt;/key&gt;
&lt;true/&gt;
&lt;key&gt;KeepAlive&lt;/key&gt;
&lt;true/&gt;
&lt;/dict&gt;
&lt;/plist&gt;
<p dir="auto">You can copy that verbatim except you'll want to change <strong>/Users/russ</strong> in this line to <strong>/Users/(your user)</strong></p>
<pre><code>&lt;string&gt;/Users/russ/.TRIGGERcmdData&lt;/string&gt;
<p dir="auto">Then just run these commands as root:</p>
<pre><code>launchctl load /Library/LaunchDaemons/com.triggercmd.agent.plist
launchctl start /Library/LaunchDaemons/com.triggercmd.agent.plist
<p dir="auto">You'll also need <a href="https://nodejs.org/dist/latest-v12.x/node-v12.21.0.pkg" rel="nofollow ugc">NodeJS installed</a> for this to work.</p>
<p dir="auto">Now we can run background commands on our macs!</p>
<p dir="auto">You can use the GUI Command Editor to create the commands, but to make them background commands, you'll need to use the Text Command Editor to switch the <strong>ground</strong> field to <strong>background</strong>.</p>
<p dir="auto">This command worked just fine to turn off my display while I was logged off:<br />
<img src="/forum/assets/uploads/files/1615938401902-3fe5a1a7-d5fb-46b6-b027-9c2f1a3a4a4e-image.png" alt="3fe5a1a7-d5fb-46b6-b027-9c2f1a3a4a4e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.triggercmd.com/forum/post/3770</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3770</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Tue, 16 Mar 2021 23:46:53 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Fri, 12 Mar 2021 00:58:50 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: Russ">@<bdi>Russ</bdi></a>, thanks for the reply! It would be great if you could please do that, in my case it would help out a lot!</p>
]]></description><link>https://www.triggercmd.com/forum/post/3749</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3749</guid><dc:creator><![CDATA[Nick Lagang]]></dc:creator><pubDate>Fri, 12 Mar 2021 00:58:50 GMT</pubDate></item><item><title><![CDATA[Reply to Log out user and Sleep on Mac? on Fri, 12 Mar 2021 00:19:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nick-lagang" aria-label="Profile: Nick-Lagang">@<bdi>Nick-Lagang</bdi></a>, I haven't implemented a background option for macs yet.  I'm thinking about how I could add that.  I found this article just now:<br />
<a href="https://www.endyourif.com/node-js-as-a-background-service/" rel="nofollow ugc">https://www.endyourif.com/node-js-as-a-background-service/</a></p>
<p dir="auto">If you're interested, I could try this myself and write a post about how to use it to run the agent in background mode on a mac, so you could use background commands that would run whether you're logged in or not.</p>
]]></description><link>https://www.triggercmd.com/forum/post/3747</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/3747</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 12 Mar 2021 00:19:53 GMT</pubDate></item></channel></rss>
