<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How can I avoid saying "TRIGGER C M D"?]]></title><description><![CDATA[<p dir="auto">Is using IFTT the way around that?</p>
]]></description><link>https://www.triggercmd.com/forum/topic/121/how-can-i-avoid-saying-trigger-c-m-d</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 23:17:35 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/121.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Dec 2017 21:56:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How can I avoid saying "TRIGGER C M D"? on Fri, 12 Jan 2018 12:17:59 GMT]]></title><description><![CDATA[<p dir="auto">@danielfruth, both skills work the same way, so if you use one of the two Alexa skills - TRIGGERcmd or TRIGGER command, then you'll have to say one of these:</p>
<li>Alexa, ask TRIGGERcmd to run X</li>
<li>Alexa, ask TRIGGER command to run X</li>
<p dir="auto">If you use IFTTT, it's a more complicated setup, but you get to say something like this:</p>
<li>Alexa, trigger X</li>
<p dir="auto">I told kent-scherler he could use the TRIGGER command skill because it does avoid saying TRIGGER C M D.</p>
]]></description><link>https://www.triggercmd.com/forum/post/447</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/447</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Fri, 12 Jan 2018 12:17:59 GMT</pubDate></item><item><title><![CDATA[Reply to How can I avoid saying "TRIGGER C M D"? on Fri, 12 Jan 2018 07:28:11 GMT]]></title><description><![CDATA[<p dir="auto">I just installed this tonight (just got Alexa too;).  After making my computer the default and figuring out I needed to say "run" in order for it to realize I had default it is getting to be pretty convenient.  However, having to say "Trigger Command" is slowing me down a little bit.  I tried the advice above to get around it but both skills seem to require it.  Did I misunderstand your statement that one of the skills doesn't need the command part?</p>
]]></description><link>https://www.triggercmd.com/forum/post/446</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/446</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 12 Jan 2018 07:28:11 GMT</pubDate></item><item><title><![CDATA[Reply to How can I avoid saying "TRIGGER C M D"? on Wed, 10 Jan 2018 09:16:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/russ" aria-label="Profile: russ">@<bdi>russ</bdi></a> said in <a href="/forum/post/383">How can I avoid saying "TRIGGER C M D"?</a>:</p>
<blockquote>
<p dir="auto">Use SmartThings and say, "turn on X" (where X is your virtual switch for your command).  &lt;-----This is the method I prefer.</p>
</blockquote>
]]></description><link>https://www.triggercmd.com/forum/post/443</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/443</guid><dc:creator><![CDATA[Nate Hales]]></dc:creator><pubDate>Wed, 10 Jan 2018 09:16:41 GMT</pubDate></item><item><title><![CDATA[Reply to How can I avoid saying "TRIGGER C M D"? on Wed, 27 Dec 2017 23:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/kent-scherler" aria-label="Profile: kent-scherler">@<bdi>kent-scherler</bdi></a>, there are a few ways:</p>
<li>Use the "TRIGGER Command" skill instead of the TRIGGERcmd skill.</li>
<li>Use a Google Assistant <strong>shortcut</strong> like my "open sesame" example for opening my garage.</li>
<li>Use SmartThings with an Alexa "routine"</li>
<li>Use SmartThings and say, "turn on X" (where X is your virtual switch for your command).</li>
<li>Use IFTTT like you said.</li>
<p dir="auto">My favorite method is a Google Assistant shortcut.</p>
<p dir="auto">Stringify has an Alexa skill and Google Assistant action too but I haven't tried them.</p>
]]></description><link>https://www.triggercmd.com/forum/post/383</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/383</guid><dc:creator><![CDATA[Russ]]></dc:creator><pubDate>Wed, 27 Dec 2017 23:04:12 GMT</pubDate></item></channel></rss>
